Subject: Installing DNN on home server.. Which article?
mr_dimsum
29 Oct 2007 12:36 AM
I am installing DotNetNuke on my home server once again after a fresh format.. Question is, which Issue should I follow to get this done right? Issue 20 dealt with installing it on Windows XP systems. My system isrunning Windows Server 2003, so I was wondering if I should follow one of the earlier tutorials that dealt with the installation procedure, or just stick with the XP one?
Looking for your guidance.
Danny
29 Oct 2007 8:56 AM
I'd probably suggest using the more recent tutorials, but be aware that configuring the IIS website might be a little bit different with Windows Server 2003. I haven't done that, and I don't have a test system running that version, so I'm guessing a bit. But, you should be able to figure out differences, if any.
30 Oct 2007 2:57 PM
watching:
How to install DotNetNuke 4.5 to Windows XP Pro with IIS
and then reading:
How to install DotNetNuke 4.3.x with SQL Server (and windows 2003)
should cover all the info that you need
Forums > Users Lounge > DNN Creative Articles > Installing DNN on home server.. Which article?
