Subject: CSS containers?
DavidWSnow
16 Oct 2007 12:01 PM
As I recall one of the Issues included a few css containers that used H1 H2 etc in the module titles. I have  searched and can't find them.
Am I wrong?
/DaveS
17 Oct 2007 3:53 AM
Those container types are used in the free skins are available in Issue no 23
