Subject: Issue 25 & XHTML Compliance
VickySwift
16 Oct 2007 7:20 AM
Issue 25 is great and I have just been through it all.
I have uploaded the files proved to my experimental site but I am getting 48 errors when I do an XHTML validation. If I change back to Andreas 09 I get the usual 1 error (which disappears when you add a page in the menu). The site is at
http://www.westovercomputing.com/Home/tabid/36/Default.aspx
Is this what everyone else gets ?
This is version 4.6.2, House of Nuke installed, compliant files uploaded, DNNC_layouts installed
Thankyou for any help
Vicky
16 Oct 2007 9:38 AM
Many of the errors that are reported when you validate your site are related to dnnMenu. You seem to be using the default menu and not the House of Nuke menu in this skin.
VickySwift
16 Oct 2007 11:17 AM
Thankyou - appreciate the quick response and apologies for not spotting that !!! Just the one error now which is the same as Andreas 09 until you put in submenu items.
Thanks again
Vicky
Forums > Users Lounge > DNN Creative Articles > Issue 25 & XHTML Compliance
Skim Question by tlsadler
Include in Menu - Weird Request by nichord
I have a request from a customer that has put me at odds.  The customer has a lot of child pages to ...
