Subject: Error in my last forum post!
stevantosic
27 Sep 2007 2:13 AM
I'm so sorry, I have put some asp.net tags (as a ascx code to ilustrate modification) in my post "Blog module modification" and causing crashing that post. I hope this problem can be resolved.
Stevan Tosic
27 Sep 2007 2:44 AM
It's ok, I managed to fix it by going into the database and deleting the post. If you wish to post ascx code remove the < and > tags - and replace them with [ and ]
You can do this quickly by using find and replace. - Press control + R - and replace all < with [
You can then post the code into the forum without it throwing a wobbly ;-)
Cheers,
stevantosic
27 Sep 2007 3:04 AM
Hi there
Thanks for help. This my first post on dnncreative. I am going to write a right post. Thanks a lot.
Regards
Forums > Users Lounge > DNN Creative Articles > Error in my last forum post!
