Subject: Tutorial for Reports Module
pcdhake
19 Sep 2007 1:43 PM
Hi Lee,
I'm a subscriber of your monthly magazine and have been very happy with your offerings. You make everything seem to simple and straight forward. Please keep up the good work.
I have a quick question for you today - I am trying to gather some information on the Reports module and was wondering if you have already published one such video tutorial on the Reports module.
If yes, can you help me find it please? I'm very bad at searching for things - they're right under my nose and I can't find 'em.
Regards,
Parry
19 Sep 2007 8:27 PM
I don't see a tutorial on the Reports module.
But, even if there isn't one, what is it that you'd like to know?
You install the Reports module just as any other module. Then, you can put the module on any page.
Basically, you configure a Reports module to include an sql query, and the module will execute the query and display the results. Presumably, you can create simple to quite complex queries. You can also display the results in a grid, with an html visualizer, or you can do an xml transformation visualizer.
If you ask some specific questions, I'm sure that we can give you some answers.
19 Sep 2007 8:34 PM
As an example ... put this in the query box: select * from users
If you leave all of the other parameters at their default values, then you'll get a table of all users registered at your site.
I'd recommend that you do your testing with pages visible only to administrators. Other words, you could put information on your public pages that shouldn't be public.
20 Sep 2007 4:11 AM
Hi Parry,
Please do not reply to the forum emails as they come directly to me, please reply in the forum, thanks, Lee
Actually, I'm thinking of using a very simple master/detail functionality into my website. There will be a grid which will display a list of records (with paging) and there'll be another panel (which would have textboxes) for the user to enter some values.
Just a typical master/detail functionality is what I'm looking for and I don't know if DNN can help me here - or if I need to build my own custom module.
Regards,
Parry
Is there any way by which we can allow "intra-module" communication ? In other words, is it possible to pass values from one module to the other ?
Regards,
Parag
20 Sep 2007 4:15 AM
In the past if I have needed to present info in master / details functionality I have created a module for it. - The latest version of XMOD maybe able to cover your needs though and would be worth a look / enquiry to the XMOD team.
20 Sep 2007 8:12 AM
Yes, if you want to create modules that communitcate with one another, look at DotNetNuke.Entities.Modules.Communications. If you google, you'll also find some other tutorials or blogs that have some examples of these object in use.
There is a very nice class browser at http://classbrowser.subzero-solutions.net/. It includes a section with all of the DotNetNuke libraries.
Forums > Users Lounge > DNN Creative Articles > Tutorial for Reports Module
