Subject: n00b getting started
y01nk
29 Apr 2006 7:59 PM
Great work, DNNCreative! I wish I would have seen these videos three months ago...
The QuickStart video series would have been perfect then!
The only I criticism I can level against them is this:
I should have known to UNZIP the folder- but I ended up going to the Flash website to see if maybe I didn't have the latest required version of Flash for the videos, and in truth, all I had to do was extract the zipped folder-
Adding a quick sentence in the read.me file instructing viewers to unzip the file would have saved this n00b about 15 minutes!
30 Apr 2006 3:13 AM
Welcome to the site! - I literally just uploaded the new updated videos yesterday, so I'm glad to hear you found the videos useful.
Doh! - That's a good point and I will add that into all of the Read Me files from now on.
Lee
Forums > Users Lounge > DNN Creative Articles > n00b getting started
