Subject: Website Subscriptions - problem
Turoc
18 Sep 2007 7:15 AM
Hi Lee
I have followed your video tut regarding setting up the site to accept paypal subscriptions. Although I have followed the video to the letter, and have not entered any info in the trial period boxes when defining the role, I am still seeing a Use Trial link in the manage services section of my registered user profile. It also shows a value of "for -1" under the trial fee header ...
How do I remove this Use Trial link ?
I am running DNN 4.5.5, and using PayPal as my processor.
Also, I want to run subscriptions like you are doing here - ie. having a seperate subscriptions page that users can subscribe off as opposed to clicking on their username etc etc.
Could you please tell us how you configured this ?
Many thanks - your site is really a mine of info and has certainly helped me to get to grips with DNN - I am loving it now, and so are my customers
Rgds,
T
18 Sep 2007 10:06 AM
Glad to hear the site is of use, it's always good to hear.  Regarding DotNetNuke subscriptions, unfortunately the trial link is currently a bug in DotNetNuke versions 4.5.X, somehow it has crept into the later releases of DotNetNuke...
The subscription system I am using on DNN creative is the subscription tools module at www.ventrian.com - I've found this module to be a much better approach for managing subscriptions than using the default subscription that comes with DotNetNuke and can highly recommend it.
Hope this is of use, thanks,
Forums > Users Lounge > DNN Creative Articles > Website Subscriptions - problem
