Subject: Live to local help
Indnut
19 Aug 2007 1:11 PM
The user is not associated with a trusted SQL Server connection.
I have followed the videos to the letter. I am trying to install a dnn 4.5.3 live host installiation to a local host to work on,
everything went as described in the video until I  go to the localhost site. Then the following error message:
The user is not associated with a trusted SQL Server connection. I am so frustrated. I have unloaded and loaded SQLserver express and started over multiple times and tried everything I can think of. Please help.
20 Aug 2007 3:21 AM
Have you managed to just install a fresh DNN localhost installation to your computer without trying to transfer a live to local installation? If you have not I would recommend you view these tutorials first to make sure that your computer is set up correctly for running DotNetNuke:
Forums > Users Lounge > DNN Creative Articles > Live to local help
