Subject: create site template
eureka
19 Apr 2006 7:34 AM
Hi Lee
I know you have made a tutorial video on how to create a site template for the wizard using the contents of a website.  However, I am unable to locate which video contains this tutorial.
Can you please tell me which video has this information.  Thanks
Regards
Lynn
19 Apr 2006 7:38 AM
Hi Lynn,
Check out this tutorial: Configuring DotNetNuke before Installation
Lee
Forums > Users Lounge > DNN Creative Articles > create site template
