Subject: live to local links to live site
rshevlin
28 Jul 2007 7:51 PM
I just finished watching videos on live to local  and have following comments...
I have found that for all links that are to local files or pages that I simply remove the http://....../ from the link that it always works local. I found this necessary when working on dnn sites that are behind a VPN wall and local users are dealing with 192.165..... and cannot link externally.
Bob Shevlin
Forums > Users Lounge > DNN Creative Articles > live to local links to live site
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
