Subject: Customizing Registration
penra
02 May 2007 4:02 PM
I completed the tutorials on customizing registration, very helpful!
Now I want to be able to get one of the fields in the Admin email when a user registers. How can I do that?
Also, if I wanted to have dropdown lists like so:
State:
List all states
Depending on the State, show a list of counties:
all counties
Depending on the County show a list of cities:
all cities
Is this doable??
03 May 2007 1:59 AM
Currently I have not found a method for exporting the custom registration fields in the admin e-mail when a user registers, I do not think this is currently available in DotNetNuke.  Also to create drop down lists dependant on previous options is also not possible in the current registration form.
Forums > Users Lounge > DNN Creative Articles > Customizing Registration
Skim Question by tlsadler
