Subject: How to create new modules
abhilashaaprakash
01 Mar 2006 9:12 PM
Is there any tutorials on how to create new modules ??
02 Mar 2006 2:32 AM
Currently there are not any videos on how to create modules. If you pop over to the DotNetNuke Resources section however you can see a list of the various tutorials that are available from other websites.
John_Stodden
03 Mar 2006 4:17 AM
Assuming you are using DNN4 and VWD and SQL Express, try the following link:
http://www.adefwebserver.com/DotNetNukeHELP/DNN_Module4/Default.htm
Also make sure you read:
http://forums.asp.net/1114393/ShowPost.aspx
Creating a module in DNN4 is much easier than with DNN3 but it still seems complex at first!
John Stodden
amit_khoje
21 Jul 2006 1:45 AM
For the site http://forums.asp.net/1114393/ShowPost.aspx
I am getting one problem. When I downloaded the starter kit and installed it.. I was expecting the
DotNetNuke Web Application Framework template
in the New Web Site option of Visual Web Developer 2005. but could not get it.
So can't proceed with the tutorial.
Please Help.
egraells
17 May 2008 7:50 AM
HAve you tried to change the language from Visual c# to Visual Basic?
17 May 2008 7:51 PM
You can write modules for DotNetNuke in either VB or VC#. If you are seriously interested in learning about DotNetNuke modules, I recommend that you camp out for a few months or weeks at Michael Washington's adefwebserver.com site. The has an entire section devoted to DotNetNuke module development. He's also author of the Module Developer's Guide.
AbhinavMoudgil
12 Aug 2008 12:29 AM
Hi.
I guess you are a beginner in DOTNETNUKE.................
Kindly go through this blog ASP.NET Basic this will surely help you in making your module and adding it in DOTNETNUKE....
Hope this may help............
Regards
Complete Search Engine Optimization Tips
Posted By abhilashaaprakash on 01 Mar 2006 9:12 PM
dnnwebuser
14 Aug 2008 5:47 AM
I am new to dotnet nuke  and unable to proceed with the pdf and the videos
Can anyone please tell me how to cretae a new template other than default.aspx and how to edit the default.aspx
18 Aug 2008 5:36 AM
It depends what you are trying to achieve. - If you are trying to change the design, this is called skinning. If you wish to create a portal template - this will auto create a set of pages and modules for you.
This may clarify how DotNetNuke works:
An Introduction to the Principles of DotNetNuke
If you subscribe to DNN creative you will have access to all of the videos.
Forums > Users Lounge > DNN Creative Articles > How to create new modules
Skim Question by tlsadler
