Subject: What happened to www.houseofnuke.com ?
hollmat1
08 Mar 2007 11:06 AM
Hi Lee,
I'm following one of your css tutorials and would like to download/install the House of Nuke menu, but the domain is suspended!!
Is there another location where I download the skin object?  Could you send me a copy?  :-)
Great site by the way.
Cheers,
Matt
09 Mar 2007 6:22 AM
Hi Matt,
I've just sent an email to Tim at House of Nuke to see what is happening and I will let you know, thanks,
Lee
Shoefly
13 Mar 2007 9:41 AM
The site still appears to be down. Any word?
dschumann
13 Mar 2007 7:04 PM
I am also waiting for the House of Nuke to return.
14 Mar 2007 5:21 AM
I sent another e-mail to Tim yesterday and hope to receive an answer soon. The site is now online but the downloads are no longer available, so it looks as though Tim is putting the site back together.
15 Mar 2007 9:25 AM
Good news, Tim has responded on the dotnetnuke forum and hopes to have the menu back online tomorrow:
http://www.dotnetnuke.com/Community/ForumsDotNetNuke/tabid/795/mid/2108/forumid/112/threadid/115570/scope/posts/Default.aspx#115696
danb
17 Sep 2007 10:11 AM
Greetings,
Was this issue ever resolved...? I've been trying to find/download the house of nuke menu, but haven't had any luck. Suggestions, or common frustrations, are welcome. Thanks in advance for taking the time to reply.
Dan
17 Sep 2007 7:53 PM
I don't know, but there are some other good menus available. I personally use and like the Snapsis Nav Menu (that's not quite the right name, but it's close) from snapsis.com.
18 Sep 2007 10:10 AM
Houseofnuke.com has been working over the past few months, the site must have just recently gone down. - hopefully it should be back online soon. If you are looking at the Snapsis Nav menu, make sure you check out the 35% discounts for DNN creative subscribers here
danb
26 Sep 2007 8:54 AM
Many thanks for the reply re. houseofnuke. I'll take a look at the snapsis plugin. Thanks again.
26 Sep 2007 9:02 AM
by the way houseofnuke is back online
Forums > Users Lounge > DNN Creative Articles > What happened to www.houseofnuke.com ?
