Subject: heavy .js pages
MWiseman
03 Mar 2007 2:32 PM
Hi Lee
I have been working through trimming down the size of my pages to increase download speeds. I have worked through the CSS as you have suggested in your tutorials and was about to change from solpart menu to housemenu with the hope of getting my pages to below 30,000 bytes. However when I run tests I find that all the DNN sites I check have .js pages, which on their own exceed my target. Is there anything I can do or need to do about this?
Mark
08 Mar 2007 4:45 AM
Hi Mark,
To stop the SolpartMenu loading the js files  you need to use the house menu for your main menu and then you need to also use the [DROPDOWNACTIONS] token in your containers.  This should help to reduce the size of your pages. Thanks,
