Subject: Convert a child portal to a parent portal
aztech
04 Feb 2007 9:45 AM
My host company doesn't allow me to create sub-domains. If I create a child portalk, so that I can see the portal online before it is ready to go live, can I then easily convert it to a parent portal with a domain name alias of the new domain name that the site will go live under. Then when I point the live domain name to the hosting company will the site be live.
Thanks for your help
Jim
06 Feb 2007 8:39 AM
hello,
Yes you can do this, we covered this in Issue no 17
In particular have a look at this tutorial:
DotNetNuke Portal Aliases
Forums > Users Lounge > DNN Creative Articles > Convert a child portal to a parent portal
