Subject: Dead Link
haasey
16 Feb 2006 3:19 PM
I'm reading the review of simple gallery and I was trying to get the video.
I'll provide more feedback on your site after the weekend when i get through more of it but so far I really enjoy it, keep up the good work.
16 Feb 2006 4:28 PM
Thanks for the feedback, and glad you enjoy the magazine, I will let you know when I've fixed the link. Thanks,
16 Feb 2006 4:41 PM
ok, all is fixed and should be back up and running, thanks for letting me know.
