Subject: FCKeditor v DNN4 WYSIWYG
MWiseman
26 Jan 2007 5:23 PM
Is the FCKeditor the same as the WYSIWYG editor in DNN4?
30 Jan 2007 7:57 AM
hello,
The FCK editor is not installed as standard when you first install DotNetNuke. The text editor used with a default installation of DotNetNuke is the free text box editor.
You'll see that in the forum on DotNetNuke.com they are using the FCK editor.
Forums > Users Lounge > DNN Creative Articles > FCKeditor v DNN4 WYSIWYG
