Subject: Portal Templates
markp
25 Jan 2007 11:57 AM
Things I have learned.
I developed a simple site on my localhost, created a template (with content) move both files to my host site, then created a child portal. (www.peacemerchant.info/lpevents). The site contained several pages, mostly hidden, each one contained a purchased gallery module.  The "style" of the module had been set on the localhost site, but no pictures were loaded.  The home page consitted of the standard HTML module and the standard links module.
1. The links in the links module lost their bearings and would actually bring you to the home page of the parents site, not of the child site (really dont like this). I have seen this with other errors, DNN hiccups on a child site and it will default to the home page of the parent site. The fix was easy, I edited every link , by changing the page it linked to drop down box to the correct page
2. The HTML module was almost perfect except it lost the picture.  The reason was easy to understand, the ref was the localhost, what was a little disapointing is the the picture was not picked up in the resource file, I had to load it through the file manager.
3.  While the purchased module did appear on the correct pages (I preloaded the module through the host function) the admin settings were lost.
I also did another test , creating a template with a site that contain a great deal of content (Phot Gallery),   I had errors and loads that, if they did finish, created errors at the applcation level.  I determined that it was the amount of data that was causing the problem.
Hope this helps someone with their development and deployment processes.
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
