Subject: RSS Article
ploraditch
27 Dec 2006 9:28 AM
Just  started my subscription.  Your content is very prolific.  I look forward to getting through it.
Finished the RSS articles and tutorial.  I get the following error msg in the latest version News Feed module running in DNN 4.3.6.   Since I have other news feeds working I assume the problem is not at my host.
Could Not Connect To http://www.dnncreative.com/DesktopModules/DnnForge%20-%20NewsArticles/Rss.aspx?TabID=99&ModuleID=400&MaxCount=25. You Should Verify The Source Address Is Valid And That Your Hosting Provider Has Configured Their Proxy Server Settings Correctly.
ploraditch
27 Dec 2006 11:18 AM
Please disregard the previous post.  The problem seems to be on my end.  I set the news feed up on another site with the same host and it is working as expected.
Skim Question by tlsadler
