Subject: Red Leaf questions
blueskies
17 Dec 2006 2:17 PM
Thanks for the sample CSS skin! I have a couple of simple questions.
Can the default.aspx 4.3.4 page provided be used with 4.3.7?
In the installation instructions you mention 2 skins and 2 containers but I only see 1 unique skin and 1 unique container download on the download page, just two different servers hosting the downloads. So I only need 1 skin & 1 container?
Thanks.
Michael
raiflex
18 Dec 2006 5:28 AM
Hi, I am also playing around with the CSS skin.
I have tried to change the default.aspx in 4.3.7, it does not seem to work. The error seems to be within web.config.
If someone knows how to resolve this error please inform us!
When you download from http://www.dnncreative.com/tabid/238/Default.aspx the two zip zipfiles container and skin version 1.2 there will be 2 skins, 3 panes and 5 panes. The containers will be a transparant container and a box container.
I hope this answers your question,
Raimond
raiflex
18 Dec 2006 7:00 AM
I checked again with changing the default.aspx page, it works, but be sure to restart the application, otherwise you will receive an error page.
Best Regards,
Raimond
Forums > Users Lounge > DNN Creative Articles > Red Leaf questions
Skim Question by tlsadler
