Subject: re your review of wildPortfolio Gallery module
John_Stodden
23 Jan 2006 4:15 AM
Hi Lee
after reading your detailed review of the above module I ordered it (DNN4 version) and am very pleased with it so far.
You made 5 "cons" at the end:
  • Can not upload images using a zip file, have to upload images individually
  • No compression on the thumbnails
  • Upload feature occasionally cuts the edges of an image
  • No preview for the images before deleting
  • Red errors permanently display in the add project function
and in the latest version that I have (1.3.3) all seem to have been fixed except for Red errrors constantly showing (which is cosmetic).
The only cons I have so far are:
a.  you cannot add the source version of the module using DNN4 as you get an error message.  You have to add the PA version and that works fine.  I have not yet tried compiling the source under DNN4 but I suspect it may need hand-tailoring first.
b.  the sorting of projects is limited  - sort order or reverse sort order, selectable by admin only.  It would be nice to offer sort by date created, project date, etc and make this sort user-selectable.
but in all a very flexible module
John B
23 Jan 2006 4:20 AM
Great, thanks for the feedback John. - It's good to hear that those issues have been addressed.
Forums > Users Lounge > DNN Creative Articles > re your review of wildPortfolio Gallery module
Skim Question by tlsadler
