Subject: DotNetNuke 5 Quick Start Guide - Issue 48
01 Sep 2009 12:37 PM
Add any comments or questions regarding the DotNetNuke 5 Quick Start Guide tutorial from issue 48
daveg955
04 Sep 2009 10:11 PM
I'm currently downloading all of Issue 48. I've glanced through the web pages for the tutorials. I'm sure that once the download is complete and I use all of these resources many of my questions will be answered... which is why I continue to subscribe. You do excellent work.
While I'm waiting for the download to complete, my question has to do with backward compatibility of 3rd party modules (ones that work in 4.9.x) with 5.x.
I understand you can't speak for the multitude of 3rd party vendors but have you run into any significant issues with backward compatibility?
05 Sep 2009 1:21 AM
I have not done that much testing with 3rd party modules yet in DNN5.x - so far I have not come across problems, but it completely depends on the module developer. Anyone else got any feedback?
05 Sep 2009 11:13 AM
I'd recommend making sure that the modules are ready for 5.x.  I have several modules that come in 4.x and 5.x modules.  Read the requirements and, when you have questions, ask!
Going forward, DotNetNuke 5.2 is going to require ASP.NET 3.5, so keep that in mind, too.
Forums > Users Lounge > DNN Creative Articles > DotNetNuke 5 Quick Start Guide - Issue 48
That will work.
DNN Creative Subscribe
