Subject: Do you know how to customize the email that is sent to regisered users?
mcox
25 Oct 2006 3:02 PM
I found how to do this by going into languages and editing the appropriate mail body fields.  There are Tolen that can be added to the email like:
Username: [Membership:UserName]
Password: [Membershipassword]
What I would like to know is... Can I add tokens to display the custom fields that I added for registration?  I want the email to be a full report of registration.
27 Oct 2006 6:32 AM
I have been trying to find a solution to this since I created the 4.3 tutorials, but I have not found anything yet. I've posted in the main DNN forum, but no-one has responded apart from other users looking for the same info.
If I find any information on this I will let you know and create a tutorial on it.
dennis
06 Nov 2006 10:29 PM
Lee,
I have several portals. If I change the text for the new user registration email will it change for all portals or can it be customised for each portal.
The only place I can find to change the text is under Languages, Global Resources.
I hope you can help me
07 Nov 2006 5:02 AM
If you go to admin / languages rather than host / languages
this will just change the text for each portal.
Forums > Users Lounge > DNN Creative Articles > Do you know how to customize the email that is sent to regisered users?
