Subject: Pure CSS SEO Layouts for DotNetNuke skins
CrizTizzy
13 Jun 2009 6:24 PM
I may be living in a fool's paradise but it doesn't seem to be necessary to do all that zip/install stuff with 4.9.   I copied over the files into a folder named "DNNC" under "skins" then went to "Host, Skins" and the folder name was available as a selection.  After that I just changed the CSS as needed and results were immediately available.
If I make changes to the HTML file then I just reparse it to recreate the aspx file.  Looks like it might even be possible just to copy the changes to the aspx file, but I'm still trying to play by, some, of the rules.
Skins are enough of a nightmare, thought it might be worth a note in case someone else is also banging their head.
I still wish comments were allowed under each tutorial because it's likely few will see this note at the same time they're going through the tutorial.
Nuke Master IV
Nuke Master IV
14 Jun 2009 7:53 AM
Yes, that's true. If you have access to the web server and to the directory, you can do things that way.
If you work with the aspx version of the skin, you don't need the .htm or the manifest file.
If you are on a remote server and can ftp or remote to the directory, it also works that way.
CrizTizzy
14 Jun 2009 8:48 AM
But, if I only work with the aspx file then wouldn't it get overwritten each time the skin was parsed?
Nuke Master IV
Nuke Master IV
14 Jun 2009 8:51 AM
If you choose to work with only the aspx file, you should delete the htm file.  YOu won't even need to parse the skin.  You just make your skin changes to the aspx file and go.
CrizTizzy
14 Jun 2009 8:54 AM
Good to know. Wish there was someway to add this info to the tutorial or redirect an old tutorial to current methods.
Forums > Users Lounge > DNN Creative Articles > Pure CSS SEO Layouts for DotNetNuke skins
RE: How to convert 3gp/avi/mp4/wmv/mpeg/mts/mov to swf by desertfish
i prefer moyea swf to video converter pro . It can easliy and perfectly convert swf to all kinds of...
NAV image menu by jmmill
Hi... I am at a loss and hope someone may have some useful advice concerning the NAV menu.I need to ...
Apostraphes showing up as Question marks by pryan@urmarc.com
This is driving me insane.On my site, the apostraphes keep showing up as "?"If I edit content in the...
RE: DNN5 custom registration page by chrissobkowicz
Interesting forum. I am looking for similar solution but I would like to call DNN 5 DLLs from cust...
As simple as: Image as a link by Helena
Hi, Trying to add an image to be link to a pdf document. After being linked to the document (in fc...
Error Loading skins by mandym
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an ...
RE: Solpartmenu fixed width Mozilla by Heinrich
The url to the website is http://www.cnetworking.co.za
RE: DNN5 custom registration page by Vimala
Yeah, Thank you. I have done it. I have make use of users & role module from module dropdown in my c...
FREE DNN Power Login module by coding-staff
Coding Staff is proud to announce a release of DNN Skins and DNN Power Login module version 1.00....
RE: DotNetNuke 5 Page and Module Permissions - Issue 51 by jedi_plex
Hello Lee, I have a problem with DNN 5 Forum module. How can I prevent some users from creating a...
RE: Add content with other role than administrator by QDelft
Yes, that was the missing factor. Thanks for the help! Sebastian Leupold answered a similar quest...
Replacing FCK Editor by jhensley
I am wondering if anyone has any recommendations about replacing the FCK editor? When I first starte...
RE: Need Best Reliable Free Web Hosting? by shalimar
hi, i currently have 2 of my sites hosted with http://www.tucktail.com/ which is a free and a w...
Restricting User Profile Settings by cpjones131
Does anyone know if there is a way to restrict Users from changing some of the their User Profile Se...
RE: Does this work with Aweber? by JamesHByrd
Yes, the tool was designed specifically for AWeber. The site has two articles that relate to it: ...
RE: How to Create a Portal Signup Module with OWS - Issue 51 by jncraig
Do you want to do that programmatically?  If so, it's really not documented very well, but that seem...
RE: How to Create a Portal Signup Module with OWS - Issue 51 by bizcomit
Ok thanks ! Where can I found a documentation of other 'dotnetnuke actions' (if exists) as 'user ...
RE: Custom Register Page by jncraig
I'll answer my question with a guess.  You are using Version 5.x of DotNetNuke.And, yes, that is the...
