Subject: Allways log in.
avilimor1
14 Aug 2006 6:20 PM
Hi Lee!
I see that when ever i enter your site I am always logged in, which I like.
Can you explain how to do that?
Thanks Avi.
16 Aug 2006 4:24 AM
This is because DNN C is currently running on DNN v 3.2.2 and asp.net 1.1
In the latest version 4.3.4 and asp.net 2.0 you will have a problem for staying logged in.
However, a tip was provided by Chris Hammond on the DotNetNuke blogs, so this should help to solve your problem,
thanks,
Lee
http://dotnetnuke.com/Community/Blogs/tabid/825/EntryID/1043/Default.aspx
Have you noticed that since running your DNN website on the .net 2.0 framework you can't stay logged in for more than an hour? Even if you have the "remember me" option checked?
Well here's your fix. In the Web.config of your DNN instance find the TIMEOUT section.
<forms name=".DOTNETNUKE" protection="All" timeout="60" />
Change the value 60 to something larger
<forms name=".DOTNETNUKE" protection="All" timeout="600000" />
This should help you to stay logged in! A very annoying feature of .net 2.0 is that it actually follows this timeout, how dare them! ;)
avilimor1
16 Aug 2006 7:02 AM
Thanks.
