Subject: House Menu
amknox
10 Jul 2008 11:18 AM
Hi all, I think I am figuring out this whole skinning thing thanks to the great tutorials and forum.
I have 2 House Menu questions:
1.
I recently installed HouseMenu 2 but it doesn't seem to be working.  I loaded the skin after installation and got the following error when I select the appropriate skin:
" A critical error has occurred. Object reference not set to an instance of an object."
There is no skin object for HouseMenu 2 should I be using skin object 1.4.1?
2.
I see that I can't use skins that use HouseMenu 1.4.1, without some tweaks in programming.  Are there any tutorials on what those tweaks should be?
Anita
10 Jul 2008 2:26 PM
I haven't used HouseMenu 2, the site says that there is not a skin object, so you will have to use v1.4.1
Also, v2 is based on the DNN Nav menu, so this will be completely different and code for the CSS menus of 1.4.1 and 1.3 will not work.
For the How to create a pure CSS skin we used House menu 1.3
For
we used Housemenu 1.4.1
All of the skins released here use 1.4.1 so you should be able to view several code examples:
ok great, glad to help,
