Subject: Diff between Host skin and admin skin?
aravinthkula
08 Jul 2008 7:18 AM
    what is difference between host skin and admin skin?
   i want to assign visitor pages to one skin (it wont contains admin and host menu link).
   Once admin / host logined that site it will change in to another skin.  how to assign like this.
Regards
Aravinth K
08 Jul 2008 6:55 PM
The host skin is the default for pages that don't otherwise have a skin assigned. The host has a default skin and an administrative skin.
The are default and administrative skins assigned at the portal level. If these are not specified, the page will inherit from the host.
Any page can have its own skin.
10 Jul 2008 1:49 PM
 you may want to have a look at: How to use Skins and Containers in DotNetNuke
Forums > Users Lounge > DNN Creative Articles > Diff between Host skin and admin skin?
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
