Subject: how to use url in skin file
aravinthkula
07 Jul 2008 3:00 AM
hi,
Could you please tell me how to give navigation URL in skin file.
currently we are using like
http://192.168.3.170/drbird/Home/tabid/74/Default.aspx"> Home
Is It correct?
while deploying i got an issue like to change the ip to current system ip.
please let me know the details.
regards,
aravinthk
07 Jul 2008 8:00 AM
You should avoid hard-coding URLs into your site.  Instead you should use relative links or take advantage of LinkClick in DotNetNuke.Common.Globals.
aravinthkula
08 Jul 2008 7:21 AM
hi
       i have used like this in my skin.ascx file.  The following code i had put in first line.
[script removed]
function NavigateUrl(url)
 window.location.href = navigate + url;
[script removed]
In page navigation url i hve used like this:
[script removed]Meet Dr.Bird
This is working fine fr me. This is right way to navigate the page?
Please help me
Regards
Aravinth K
10 Jul 2008 1:25 PM
Are you aware that you can use:
<%= SkinPath %> in your skin.htm file to fill in the URL of your domain and skin folder
But not sure if it will be helpful if you are wishing to link to pages
Forums > Users Lounge > DNN Creative Articles > how to use url in skin file
Glad you sorted it, thanks,
