Subject: vertical scrolling container
aggiedan97
30 Jun 2008 12:05 PM
I am working on a fixed skin and have a need for a fixed container height which I would like the containing text to scroll vertically it it exceeds the height of the container.
Perhaps I am making this too difficult, but I would appreciate your initial thoughts.
30 Jun 2008 8:44 PM
Take a look here: http://dnncreative.com/Forum/tabid/88/forumid/13/tpage/1/view/topic/postid/5152/Default.aspx#5158
Forums > Users Lounge > DNN Creative Articles > vertical scrolling container
