Subject: Creating a sub-domain parent portal and a child portal with dotnetpanel
antonioff
14 May 2008 9:35 PM
I look in the tutorial how to add headers to point one IP in resellerchoice with the hosting controller panel; but what about dotnetpanel that it is now the new control panel resellerchoice has. Is it possible to add host headers with that new control panel ?
Somebody know if is it possible to use with dotnetpanel host headers?
Thanks.
17 May 2008 7:51 PM
I think that this probably is best taken up with the ResellerChoice tech support people.
RC-Rob
03 Oct 2008 10:46 PM
ResellerChoice dotnetpanel host headers are now called "Domain Pointers"
To add Domain Pointers, Login to DotNetPanel
1. Enter the hosting space that contains the web site you wish to configure
2. in the left menu click "web sites"
3. Click the web site you wish to configure
4. To add a web site pointer, click Add Web Site Pointer button. Add Web Site Domain Pointer page will open.
Select an existing domain from the drop-down box and click Add Pointer button. New web site pointer will be created.
To delete an existing web site pointer, just click button and confirm removal.
Reliable and Fast DotNetNuke Hosting -
Windows VPS Servers -
Windows Dedicated Servers
www.ResellerChoice.com
Forums > Users Lounge > DNN Creative Articles > Creating a sub-domain parent portal and a child portal with dotnetpanel
