Subject: Issue 29 article on token replacement
ctaswell
01 May 2008 4:48 PM
The article and demos discussed token replacement in selected modules such as UDT and Text/HTML. Also mentioned possibility of using tokens in other modules in future.
So is there any news/update on either availability or plans for use of this token system in other modules?
Are the tokens discussed in the article completely separate from the tokens used for skin objects by the skinning mechanism? Or do they work with each other?
For example, can a token like [Portal : PortalName] be used by the skinning system?
If not, are there any plans to devise a token system that is consistent throughout all of DotNetNuke? If so, is that what is planned for the Cambrian release?
How about doing an interview with a core team member and publishing it in the next issue? You could relay our concerns and ask our questions? And all your subscribers would benefit!!!
CT
06 May 2008 5:21 AM
As far as I know, the token system is planned for future implementation in other modules.
The tokens are separate from the tokens that are used in skinning.
The skinning engine will probably change in the Cambrian release, but I do not have any information on those changes.
If you want to hear about tokens have a listen to this interview with Sebastian Leupold
Forums > Users Lounge > DNN Creative Articles > Issue 29 article on token replacement
have a look here
Database error by derpir
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
MY FIRST DNN SITE by mattshortland
hello I am just working on my first dnn site and wondered what you all think? http://letcombebass...
New CSS site feedback please! by dp6ai
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen ...
I have added a new Profile Property to Users (Company name) Does anyone know how to change the la...
