Subject: CRC Error
wcmason
01 May 2008 1:03 PM
Hi Lee,
There is an error in the latest wmv download.  I downloaded twice from the US location and once from the UK location.  It looks liek a problem with the shadow modules file.  Below is the zip file output:
Bill
(removed for security)
ctaswell
01 May 2008 1:40 PM
I can confirm I had same problem. Thanks much for fixing and re-releasing.
01 May 2008 1:44 PM
ctaswell,
I have not made a fix, does the zip file open for you?
I will download and double check the files from here as well, thanks,
Lee
01 May 2008 2:09 PM
ok, I have checked it and yes there is an error.
I have repackaged a zip and it is currently uploading. I am uploading to the America server first so that you can start downloading as soon as possible. The FTP programme says it will be 60mins before the file has finished uploading to the America server. Once that has complete I will upload to the UK server which will be another 60mins after that.
Thank you for your patience,
Lee
ctaswell
01 May 2008 2:34 PM
I'm neither Aussie nor Brit... but as the Aussies say... No worries mate! You do a great job! So no rush..
In my post below confirming the error, I should have said "thanks in advance" instead of just "thanks" which would have prevented the confusion...
01 May 2008 3:46 PM
ok, the US server has uploaded and is working. The UK server is currently uploading,
Lee
01 May 2008 4:41 PM
UK server is uploaded and working, thanks,
Lee
wcmason
02 May 2008 5:27 AM
Hi Lee,
Downloaded from the US site and everything works great now.
Bill
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
