Who can edit events in the events module?
Last Post 2008-04-07 09:31 AM by Lee Sykes. 1 Replies.
Michelle TarbyUser is Offline
2008-04-03 12:01 PM
I can't seem to find a way to do this - as a portal administrator, I can edit events that are posted in the events module, but is there a way to allow a user in a different security role access to edit a specific event?  They do have edit permissions assigned to the module, yet the delete and edit options don't appear.
Thanks in advance!
2008-04-07 09:31 AM
I don't think this is possible, a user can edit and delete events that they create, but I don't think you can enable them to edit specific events.
Issue after making site Live by Sameer
Hi All i am using DNN 6.1.3 for my site every on my server working good but as i send the databas
User Autrhority by Kaustav
Hi, Here are the requirements for my site • PDF documents repository, each doc less th
RE: Active Forums vs. DNN 6.2 CE by Pingle2009
I haven't previewed DNN 6.2 RC either (nor, by default, the AF Beta module). My understanding from p
RE: DNN 6.2 by Sameer
Thanks joseph my issue is resolve
RE: PCI Compliance with PayPal integration by Joseph Craig
I'm hardly an expert. I took a quick look at http://www.pcicomplianceguide.org/pcifaqs.php. He
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
