Referencing web service error!
Last Post 2008-07-31 11:41 AM by satyendra. 2 Replies.
JikuUser is Offline
2008-03-27 12:22 AM
I have created dnn module and add a web reference.  When i package and install the module in different nuke project, it raises the error of not find the webservice reference.  So in my dnn project, i drag the web reference from App_WebReferences folder to App_code\MyModule1 folder ... then i package the dnn module and installed in different nuke projects ... it runs fine...
I have created another module and reference the same web reference to the second modules app_code\MyModule2 folder
But it is not able to compile and raise the following error :
Error 1 The type 'RService' exists in both 'c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\root\de556104\a30f065c\App_SubCode_RLineList.e-tc2zhh.dll' and 'c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\root\de556104\a30f065c\App_SubCode_RSearch.fgrnwrox.dll'
C:\Rlink\DevDNN\DesktopModules\RLineList\ViewRLineList.ascx.cs
118 13 http://
how can we reference the same web service for the second module without causing an error ...
SupaHoopsaUser is Offline
2008-05-06 02:49 PM
Did you manage to resolve this?
I am facing exactly the same problem
satyendraUser is Offline
2008-07-31 11:41 AM
I have created a new module that retrieves the data it requires via a WCF. When i create a package and install this module in different nuke project, then i got the WCF reference error.
So how can we add a WCF reference in Module Package.
When we install these module ith other DNN project then automatcally add the WCF reference.
Please help me.
DNN nav issue by imran shaikh
