In one Module two view controls
Last Post 2008-03-12 02:49 PM by Joseph Craig. 1 Replies.
Ravi kumarUser is Offline
2008-03-11 11:21 AM
I am new to these DotNetNuke.i am using DotNetNuke4.7 .i have module with two view controls. when i click on the link button another view control should be loaded in content pane.
I tried with navigate url but i am casting error.
plz any one  help on these.
plz give the sample example.
i search in all forums also.
2008-03-12 02:49 PM
I'd recommend that you study Michael Washington's adefwebserver.com site. He has an area dedicated to module development issues.
DNN nav issue by imran shaikh
