Changing color of Login
Last Post 2006-06-16 07:35 AM by Lee Sykes. 1 Replies.
Mark TracyUser is Offline
2006-06-15 08:44 PM
    I am trying to change the color of my login to white.  I found some info on the asp.net forums, but it didn't work.  If you look at the code from the files below you can see I created a Css class named LOGINCHG in my .xml file and in my .css file I change the color to white.  Will this not work?
    skin.xml
    <Objects>
     <Object>
      <Token>[LOGIN]</Token>
       <Settings>
        <Setting>
         <Name>Text</Name>
         <Value>Register/Login</Value>
        </Setting>
        <Setting>
         <Name>CssClass</Name>
         <Value>LOGINCHG</Value>
        </Setting>
       </Settings>
     </Object>
    </Objects>
    skin.css file
    .MainMenu_MenuItem {
     color: white;
    .MainMenu_SubMenu {
     color: black;
     background-color: blue;
    .LOGINCHG {
     color: white;
    2006-06-16 07:35 AM
    Yes that should work. - First thing is to press refresh a couple of times, sometimes it takes time to take effect.
    2) - Download the FireFox web developers Toolbar
    this is an essential tool that I use all the time for skin development. - Once you've installed it, open your skin in Firefox and select Information / Display ID & class details - You will then be able to view the class that is associated with the Login links.
    From this you will be able to see if you have made a mistake somewhere for setting the class for the login links.
    The other really useful tool in the toolbar is to go to CSS / Edit CSS - this allows you to test CSS settings live and doesn't change the original CSS file.
    Hopefully this will help you troubleshoot your skin to see where the problems are occurring, thanks,
    Issue after making site Live by Sameer
    Hi All i am using DNN 6.1.3 for my site every on my server working good but as i send the databas
    User Autrhority by Kaustav
    Hi, Here are the requirements for my site • PDF documents repository, each doc less th
    RE: Active Forums vs. DNN 6.2 CE by Pingle2009
    I haven't previewed DNN 6.2 RC either (nor, by default, the AF Beta module). My understanding from p
    RE: DNN 6.2 by Sameer
    Thanks joseph my issue is resolve
    RE: PCI Compliance with PayPal integration by Joseph Craig
    I'm hardly an expert. I took a quick look at http://www.pcicomplianceguide.org/pcifaqs.php. He
    RE: DNN 6.2 by Joseph Craig
    DNN 6.2 by Sameer
    RE: Deploying dnn by Sameer
    Thanks a lot so kind of you
