domain name
Last Post 2010-03-11 12:19 PM by aventhika123. 2 Replies.
mohini padayacheeUser is Offline
2006-06-08 01:41 PM
I have set up a parent portal and several portal aliases with a domain name 'healthdevelopment'. This domain name will change once we are finished with the development. How is this achieved and how do the child portals inherit the new domain name? Do I have to change  the domain name of each child portal?
Many thanks
mohini
2006-06-08 02:16 PM
I have not done this in practice, but I think it will be a simple process:
If you log in as Host go to the Host menu / Portals
Here you will see a list of all of your portals
Click on the edit pencil icon for one of your portals
Scroll to the Bottom
Click on Add New HTTP Alias
Type in the new URL you require - if it's a child portal make sure you enter the full URL with the new domain name - also NOTE: do not include http:// - just enter: www.mynewsite.com/portalname
Repeat this for all of the portals
Navigate to each of the new URLs to check that they are working correctly
Once they are working correctly you can go back to the each portals HTTP settings and delete the original domain name.
Hope this helps, thanks,
aventhika123User is Offline
2010-03-11 12:19 PM
Hi, for expected Domain name use this http://www.xnynz.com/ site ,here only i got my all sites domain name at very low cost ,you also may try it.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
