Using Intranet
Last Post 2006-06-07 04:29 PM by Lee Sykes. 1 Replies.
Sunil RajUser is Offline
2006-06-06 03:59 PM
    If I'm planning 2 install in my own pc n use it 4 intranet purposes wat do i need?
    Thx alot.
    2006-06-07 04:29 PM
    Hello, welcome to the site.
    Have you installed DNN at all? Which version are you going to install?
    DNN3.x and 4.x differ in their requirements. I don't have any tutorials for installing DNN to a localhost installation so I would recommend you check out these resources:
    The main DNN documentation: http://www.dotnetnuke.com/tabid/125...fault.aspx
    which details information for installation and what you need.
    http://www.traincert.net/">Traincert offers a free local installation video covering installation for DNN3.x
    If you are using DNN3.x you will need to install MS-SQL server - If you are installing DNN4 you can download the free http://msdn.microsoft.com/vstudio/e...fault.aspx">SQL server Express that comes with Visual Web Developer Express.
    Hope this gives you some starting points, thanks,
    I'm confused by this, too.
    We are running DNN 6.x
    You should be able to use CE even if you have a high traffic site. To develop your site without p
    RE: Rename or move site from domain name to subdomain name by Joseph Craig
    It is easy. 1. Go to Admin, Site settings and add a Portal Alias for new.websitename.com 2.
