DNN 4.7 install - missing ASP.NET tab
Last Post 2008-05-09 03:38 PM by Joseph Craig. 9 Replies.
Ray MasoudiUser is Offline
2007-12-17 10:14 PM
Uisng Win XP pro,  SP2 ,  32 bit processor
I am trying to install DNN 4.17 (clean install not upgrade) on my local PC. >NET framework 1.1. and 2.0 in insatlled on my PC.   on the IIS manager "ASP.NET " tab is missing .    I can't set my IIS to use .NET 2.0 and I am stock. I have checked my resigtry values for follwing keys and all have 2.0.0.0
HKEY_CLASSES_ROOT\CLSID\{7D23CCC6-A390-406E-AB67-2F8B7558F6F6}\InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FD5CD8B1-6FE0-44F3-BBFB-65E3655B096E} \InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FEDB2179-2335-48F0-AA28-5CDA35A2B36D}\InprocServer32\
I would appreciate any help.
2007-12-18 12:42 AM
I'm not that knowledgeable about installing and configuring IIS and ASP.NET. Hopefully someone who is will chime in. But, if something is missing, you might want to try to unistall and then reinstall IIS.
2007-12-18 01:10 AM
I did uninstall and reinstall the IIS did not help.  Still  ASP.NET  tab is missing.
2007-12-18 08:34 AM
This is not something I have come across before either.  If I were approaching this I would search the microsoft related forums for any tips, if I couldn't find a solution I would use Virtual PC and create a separate install of windows XP and try again from a fresh installation.
I use virtual PC for all my development work now and if you are just starting out it is well worth looking into.
Let us know if you find a solution, thanks,
Lee
2007-12-26 07:29 PM
Hello all
Here is how I solved it
1. Make sure there is an entry(folder) under  following keys names 2.0.0.0
2. Try Looking in [HKEY_CLASSES_ROOT\Typelib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] and [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] for the word "Path" in any values.  This was causing my asp.net Tab from not showing up. Replacing the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\0\win32 with C:\WINDOWS\\Microsoft.NET\Framework\v2.0.50727\AspNetMmcExt.tlb and the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\HELPDIR with C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727 worked for me when all other suggestions failed.  This is taking for granted that you have .Net 2.0 installed.  If you do not, look at these keys for a like machine that is showing the tab and use thoses setting for the above keys.
Note: if  regeedit does not allow editing a key, click on right mouse, permission, give full control for yourself then it will let you edit it.
2007-12-26 08:47 PM
I'm glad you found the solution!
2007-12-27 09:33 AM
Thanks for taking the time to post a solution, hopefully others will find this useful as well. - Happy nuking!
amuluriUser is Offline
2008-05-09 06:54 AM
Hi  all,
Am also not getting the ASP.Net tab in IIS . I tryed going your way of editing the key strings but the problem is that I couidint find the file in which this key is situated . Please help me in resolving this problem.
Thanks in advance.
Raju..
2008-05-09 06:54 AM
Hi  all,
Thanks in advance.
Raju..
2008-05-09 03:38 PM
You might try uninstalling IIS, rebooting, and then reinstalling it. If you don't have the ASP.NET tab, check (Add/Remove Programs) to make sure that ASP.NET is installed. If it isn't, download and install from the Microsoft web site.
If none of these suggestions help, ask again.
DNN nav issue by imran shaikh
