Remove Register button
Last Post 2010-01-21 02:10 PM by Joseph Craig. 10 Replies.
Oliver AcevUser is Offline
2007-12-11 10:21 AM
Can you help me how to remove register button from LogIn module
2007-12-11 10:28 AM
go to the admin menu/site settings
advanced settings
security settings
under 'user registration' select none
2007-12-11 10:40 AM
Thank you very much
JohnUser is Offline
2009-11-21 04:32 PM
Is there a way to have the Register/Account button read "Register/My Account" instead of "Register/Displayname"?
2009-11-22 03:53 AM
Yes, you can change the text using the Language Editor.
JohnUser is Offline
2009-11-22 07:17 PM
I know you can change the "Register" text but I don't see where you can have it say "My Account" instead of "DisplayName" once the user is logged in. Am I missing something?
2009-11-22 11:55 PM
Oh, I misunderstood the question.
I think that the simple question is that you cannot do that with the USER skin object.
On the other hand, it wouldn't take much work to create a skin object that does what you'd like for it to do.  There is a line in the user.ascx.vb file that reads:
                      cmdRegister.Text = objUserInfo.DisplayName
Change it to:
                      cmdRegister.Text = "My Account"
and you'll have what you want.
I would copy the existing USER skin object, and create a new one called USER1.  That way, you can always to back to the original.  Additionally, upgrading won't overwrite your version.
2009-11-23 12:03 AM
If you decide to create a special skin object, look here for information about packaging it for installation.
JohnUser is Offline
2009-11-23 12:35 AM
Jerry AndersenUser is Offline
2010-01-21 01:49 AM
Can you please direct me where in the language editor I can make this change? Thank-you. Jerry
2010-01-21 02:10 PM
Open Languages, Language Editor.
Expand Local Resources, Admin, Skins, App_Local_Resources and look for the User control or the Login control, or whichever control for which you want to alter text.
