transferring localhost to live server
Last Post 2007-12-10 09:01 AM by Lee Sykes. 1 Replies.
webmonkeymonUser is Offline
2007-12-06 06:09 PM
i have gone through these tutorials just fine, but twice when I got to the point of changing the web.config file.  IIS will no long have access to the database locally.  the errors were permission errors.  And the kicker is if you just change the webconfig file back to what it was, it still will not give access to the data base.  It will gain access to the databse if I use the  VWD built in webhost.  so if i right click on the site and say show in browser it will run using a localhost a url like this
http://localhost:2168/4602BETA
the errors varied based on my track to hack this but they are all basically this.
Cannot open user default database. Login failed. Login failed for user 'WEDONTCAREWHATD\ASPNET'.
errors are all permission errors
I probably will just extract the skins from it and let it die since there is no data in it.   this post on dnn seems to suggest that it is not worth trying to fix.  Which I agree, especially in my case, but it would be nice to know what causes this serious problem.
I think this may have to do with the setting in sql express about using both windows and sql, which was not an option in the latest version.
see.  http://www.dotnetnuke.com/Community...fault.aspx
2007-12-10 09:01 AM
What is detailed in that post is exactly the method I have used in the video tutorial, except for the login section. - I would suggest you re-watch video two: http://www.dnncreative.com/Localhos...fault.aspx
Have you created a new login account to access your database? and specified those details in your web.config file?
DNN nav issue by imran shaikh
