Register Form
Last Post 2007-12-21 08:11 AM by Lee Sykes. 4 Replies.
saintXUser is Offline
2007-12-06 02:11 PM
With excellent tutorials of Lee and kind help of this forum user I am about to finish my first DNN project. But some of the change requests of the clients are unusual.
I had to change the standard fields of the registrierungs form in this way:
Bitte geben Sie Ihren Vornamen ein!
Bitte geben Sie Ihren Namen ein!
Bitte geben Sie Ihren Firmennamen ein!
Bitte geben Sie Ihre Position ein!
Sie müssen eine gültige E-Mail-Adresse angeben.
Now, as you see all of the fields are required. I must chage the values of the 3rd. and 4the fields to not required (it's no possible to do this in admin/user accounts), and make some changes so that the last name be dispalyed as the user signs in. It's not usual, but I hope possible,
thanks
2007-12-10 08:39 AM
hello,
You may be able to achieve this with this module: datasprings dynamic registration module
I have not used this module before, so it would be worth contacting the module developer to see if it covers your problem,
zealousweb1User is Offline
2007-12-20 05:49 AM
I want to Change my Registration Form fields.
Like
FirstName
MiddleName
LastName
Email
Address
City
State
Telephone No
Fax
Website
But how can i do it ?
Please help me.
Thanks in advance.
2007-12-20 02:49 PM
Take a look at the DataSprings Dynamic Registration module that Lee mentioned earlier in this thread.
2007-12-21 08:11 AM
for anyone else reading, there was also a solution posted here:
http://www.dnncreative.com/Forum/ta...fault.aspx
DNN nav issue by imran shaikh
