Replace Tokens w/ HTML Module
Last Post 2011-10-18 09:02 PM by IntelligentNetware. 24 Replies.
Page 2 of 2 << < 12
Gustavo RodriguezUser is Offline
2011-03-02 02:45 PM
Hi Joseph,
Thanks for your quick answer; we're not using the Text/HTML module, rather the Events module (that comes with Dnn) this is where, inside the e-mail templates option, we want to be able to insert these tokens into the email templates.. I've tried using what you suggested without succes... is there anyway to make this work?
Thanks again!
Joseph CraigUser is Online
2011-03-02 03:43 PM
There is a list of tokens here: http://www.dotnetnuke.com/Community...fault.aspx
There may be others. For a definitive answer, I'd suggest that you ask at the DotNetNuke.com forum for the Events Module.
2011-03-17 06:17 PM
Hi Joseph, and thanks,
I tried using the tokens but there's no token replacement option on the module.
The specific module is the EVENTS module that comes with DNN, I'm trying to insert the tokens in the Event email templates, as I mentioned, there's no token replacement and the defined tokens won't seem to work either.. what is it that I'm might be missing here.. is this even possible??
Thanks in advance
2011-03-17 08:54 PM
There is a set of tokens that are specific to the Events module.
For really good help with the Events module, I do recommend that you also visit the Events Module forum at dotnetnuke.com. The team responsible for that module seems to be one of the best and is quite helpful.
IntelligentNetwareUser is Offline
2011-10-18 09:02 PM
Is it (and how) possible to display tokens in an HTML (best) or REPORT or FnL module for (admin only) to view any UserID?
In other words, I'm trying to let an admin view all the Profile Properties for any registered user, by the TOKENS only show the currently logged in user - not any other User's data.
I know I can use the User Profile Properties Template to display this but the template is limited to 4000 characters even after changing the default database field limits from 2000. This means I can only display 1/5th of the fields. So I've tried everything I can think of.
Your pointers?
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
