Logo being able to stretch it
Last Post 2006-05-08 10:56 AM by Lee Sykes. 3 Replies.
ROelof ElzingaUser is Offline
2006-05-06 07:36 AM
I am trying to have the logo go on top of the page but everytime I create it it only gives me about half of the page
http://games.servehttp.com/DNN4/
As you can see the logo stays on the left site. How can I stretch it across the top of the page, or at least insert other items on the right side. I use the standard skin for this product.
2006-05-06 11:39 AM
Hello, the link doesn't seem to be working, is it correct? thanks,
David YoungUser is Offline
2006-05-06 04:59 PM
If you haven't adjusted the skin then that cell is split into two. On the left is the token is [LOGO] and the right is the [BANNER].
This process is explained in Lee's excellent videos on creating skins. He can give you the correct number on this.
What we are going to do is make a quick custom skin.
You should have a local install of the DNN you are using on the website on your computer.
  • Open the install and go to portal/default/any color/ and copy its contents to a seperate location on your hard drive. c:\SkinWithoutBanner for example.
  • Open the HTML file in an editor of choice. Notepad is fine. Locate the [BANNER] token in a table cell towards the top. Change the  [BANNER] cell to <td id="LOGORIGHT" runat="server" valign="top" align="center"></td>
  • Save
  • Zip the files in the directory into a zip file called SkinWithoutBanner.zip
  • You should really run this on your local install first to make sure it works. If this isn't possible then FTP this zip file to your host site into the install/skins folder. You should see a placeholder file in it.
  • In your browsers address line run http://<something.com>/Install/Install.aspx?mode=Installresources
  • This will install your new skin
  • Log in as administrator
  • Change the page or portal to use this skin. It will be called SkinWithoutBanner, doing it on a page would be best to see if it works
  • Now you can add a module to the new choice called LOGORIGHT the same way you add any modules
This is a very simplified way of doing what I think you want to do. Since you paid for the videos from this site and Lee goes into far more detail than I outlined here I would strongly encourage you to watch them. Then you'll get the reasons of what I did as oppossed to just following some simple lines
2006-05-08 10:56 AM
The videos youngboy is referring to are in issue 5 and 6: http://www.dnncreative.com/Home/Iss...fault.aspx
In particular check: 'How to create a skin for DotNetNuke'
Setup Preparations for Skinning Video Tutorial
(10 min)
Introduction to skinning in DotNetNuke Video Tutorial
(12 min)
How to create a skin for DotNetNuke Video Tutorial
(8 videos and skin - 70 min)
How to create a container for DotNetNuke Video Tutorial
(2 videos and container – 16min)
Let us know how you get on,
DNN nav issue by imran shaikh
I successfully installed DNN 6 on my local machine using IIS 7.5. Its working good. When I attach to
RE: Module Security permissions by Bhushan Gholap
Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
RE: There's a tutorial for this somewhere by Eric W
The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
RE: DNN 6 Modules Not Showing by Joseph Craig
Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
RE: DNN 6 Modules Not Showing by Mike DeBaise
No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
