Event Module Time Edit?
Last Post 2007-10-04 06:01 PM by Jason Harlow. 2 Replies.
Jason HarlowUser is Offline
2007-10-04 01:57 AM
Looking for info on how to change the default time options in the event module.
Currently all the options in the drop down are in 30 minute increments. I have a requirement for something to occur at 6:15 (not 6:00 or 6:30). I may be overlooking something but I don't see where I can add that.
Anybody ran across this?
thanks
jh
Joseph CraigUser is Online
2007-10-04 03:20 PM
Go to the Event module's settings and find the Edit Time Interval Setting. It's the first one under General Settings. Set that to 15 minutes, or whatever you want to use.
2007-10-04 06:01 PM
Thanks jncraig. I almost didn't even put the post up because I ikinow it was going to be something easy.
Thanks for the info. BTW, can you or lee email me? I may have something I'd like to speak to you about, but not on a forum.
Issue after making site Live by Sameer
Hi All i am using DNN 6.1.3 for my site every on my server working good but as i send the databas
User Autrhority by Kaustav
Hi, Here are the requirements for my site • PDF documents repository, each doc less th
RE: Active Forums vs. DNN 6.2 CE by Pingle2009
I haven't previewed DNN 6.2 RC either (nor, by default, the AF Beta module). My understanding from p
RE: DNN 6.2 by Sameer
Thanks joseph my issue is resolve
RE: PCI Compliance with PayPal integration by Joseph Craig
I'm hardly an expert. I took a quick look at http://www.pcicomplianceguide.org/pcifaqs.php. He
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
