site speed
Last Post 2006-05-04 08:22 AM by Lee Sykes. 1 Replies.
lynn WalshUser is Offline
2006-05-03 11:21 PM
Hi Lee
 Apart from using blowery compression, css skins and containers. Do you have any good tips to speed up a DNN site?
Lynn
www.artreach.net
Inspiration For Life
www.seemalta.net
see Malta
2006-05-04 08:22 AM
Hi Lynn,
The next step is to regularly ping your DNN site. (If it is a low traffic site). What happens is if your site has not been accessed for around 5 to 15mins, the server will remove your site out of it's memory. So when a user visits your site, the server has to load your site into it's memory, which usually takes around 17secs. - If it is already in it's memory it loads the site straight away.
So if you have a site with a 35k size page the time it will take to load is 17secs plus the time it takes to load 35k.
The workaround to this is to regularly ping your site - ie. automatically get another site to visit your site every few minutes to keep your DNN site in the servers memory.
There are modules that you can buy to do this, but there is a better and free way. - Go to http://forums.asp.net/thread/1235032.aspx
Issue after making site Live by Sameer
Hi All i am using DNN 6.1.3 for my site every on my server working good but as i send the databas
User Autrhority by Kaustav
Hi, Here are the requirements for my site • PDF documents repository, each doc less th
RE: Active Forums vs. DNN 6.2 CE by Pingle2009
I haven't previewed DNN 6.2 RC either (nor, by default, the AF Beta module). My understanding from p
RE: DNN 6.2 by Sameer
Thanks joseph my issue is resolve
RE: PCI Compliance with PayPal integration by Joseph Craig
I'm hardly an expert. I took a quick look at http://www.pcicomplianceguide.org/pcifaqs.php. He
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
