Manage Profile Properties Does Not Update
Last Post 2007-10-03 11:55 PM by AlanJ. 2 Replies.
AlanJUser is Offline
2007-10-02 09:25 PM
Within the User Accounts there is a page Manage Profile Properties.  I have selected several of these properties and have made them visible.  I have also clicked on Update.
However, when someone goes to register, they still see only the original selection of properties.  What am I forgetting?
Thanks in advance,
Alan
Joseph CraigUser is Online
2007-10-03 03:35 PM
If you want to require that users fill in certain property values, you need to make them "required." Also on the "User Settings" page are options that can require a valid profile for login and a valid profile for registration.
2007-10-03 11:55 PM
Dear Joe,
Thank you. I had in my mind that the application would work in a certain way. It worked differently.
Alan
Issue after making site Live by Sameer
Hi All i am using DNN 6.1.3 for my site every on my server working good but as i send the databas
User Autrhority by Kaustav
Hi, Here are the requirements for my site • PDF documents repository, each doc less th
RE: Active Forums vs. DNN 6.2 CE by Pingle2009
I haven't previewed DNN 6.2 RC either (nor, by default, the AF Beta module). My understanding from p
RE: DNN 6.2 by Sameer
Thanks joseph my issue is resolve
RE: PCI Compliance with PayPal integration by Joseph Craig
I'm hardly an expert. I took a quick look at http://www.pcicomplianceguide.org/pcifaqs.php. He
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
