Wow!
Last Post 2007-09-11 06:21 PM by Daniel. 0 Replies.
DanielUser is Offline
2007-09-11 06:21 PM
    Being a well-seasoned graphic artist, I have 15 years of experience with most design software out there, and I discovered that DNN was nothing like anything I’d ever used before. I even tried learning the program through the DNN for Dummies book. I just didn’t understand the concept clearly at all.
    The tutorials have truly opened the DNN Doors for me. They are extremely concise, easy to comprehend and follow along with. Although I’m still very much of a novice in this environment, I now have hope that I’ll actually be able to develop an awesome website for our business using DNN. Thank you!!!
    Best Regards,
    D Bayerdorffer
    DNN nav issue by imran shaikh
