How to remove the copyright notice
Last Post 2009-05-08 09:13 AM by Lee Sykes. 3 Replies.
2007-09-10 12:40 PM
The default installation of DotNetNuke will display copyright information in the source code for DotNetNuke. It is not a requirement to display this copyright notice so if you wish to remove it use the following steps:
  • login as host
  • go to the host menu / host settings
  • scroll down to 'appearance'
  • un-tick show Copyright credits
webologyUser is Offline
2009-05-07 08:36 AM
i did this steps but Copyright still apper in footer ?
Joseph CraigUser is Online
2009-05-07 06:35 PM
Lee's instructions will remove the copyright that refers to DotNetNuke. There is also a site copyright. If you want to remove that, you will need to edit your skin to remove it.
And, you may have a skin file that has copyright information inserted directly. If that is your case, you will need to edit the skin file.
2009-05-08 09:13 AM
Just for your info, the text of the copyright can be changed from the admin menu / site settings.
However you can not remove the copyright text completely, to do that you need to remove the [COPYRIGHT] token from the skin.
FCK Editor in DNN 6 by WinXnet
is there a way to get the FCK editor working in DNN 6 - it has stopped funcitoning properly after an
RE: Deploying dnn by Sameer
Just sent it.
