4.5.2 New Search Web Option Disable
Last Post 2009-03-31 07:35 PM by Lee Sykes. 4 Replies.
Jason HarlowUser is Offline
2007-06-03 01:47 AM
If you were like me, you were suprised to see your skin change when the 4.5.2 upgrade came out with a new "web" and "site" search option.
You can remove these options by putting the following code in your skin file for your search box.
<dnn:SEARCH runat="server" id="dnnSEARCH" CssClass="Skinobject" showweb="false" ShowSite="false" />
The Search SKO has 3 new attributes:
   Attribute Values Default Description
• ShowSite True, False True display/hide option "Site" to perform a search of the current site (DNN portal)
• ShowWeb True, False True display/hide option "Web" to perform a search of the WWW using the search site, as set up in Site Settings (Google, Yahoo, MSN)
• UseWebForSite True, False False use the WWW search Site, as set up in Site Settings,  to perform searches of the current site (DNN portal). Note: this uses the search index stored at the the search site; any non-public content will not be included!
I found this hidden on DNN site here: http://www.dotnetnuke.com/Community...fault.aspx
thanks
jh
2007-06-05 12:00 PM
Thanks, that's useful,
JoeBommaritoUser is Offline
2009-03-29 05:19 PM
Will this remove the site/web search from the menu bar all together?
 I want to remove it all together. i need the space on the menu bar.
2009-03-29 05:21 PM
IF you want to remove search completely, go and edit your skin file and remove the token/tag.
2009-03-31 07:35 PM
Just to update this thread, we have a tutorial here:
How to style and skin the search box in DotNetNuke
informative!!!
informative!!!
